It is currently Fri Aug 15, 2025 3:29 pm
 Post subject: end grain in a rosette?
PostPosted: Thu Dec 18, 2014 11:26 am
Last Name: Sollod
Is there any reason not to use end grain in a rosette? ...perhaps problems associated with finishing... There are some interesting designs in some end grains that might look nice in a rosette. I have some palm that has dots in the end grain and strips on the side. I thought a combination would make an interesting rosette design...
www.swiftcreekguitars.com
These users thanked the author sdsollod for the post: Jfurry (Sat Dec 20, 2014 7:06 pm)
PostPosted: Thu Dec 18, 2014 11:28 am
I wouldn't anticipate a problem, particularly if you flooded it with thin CA...
PostPosted: Thu Dec 18, 2014 11:37 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
All those tiles made from logs of veneer are endgrain. . . Palm endgrain does look cool. It might be a bit tougher leveling it next to the much softer spruce but I think if you are careful it should be fine.
Bryan Bear PMoMC
PostPosted: Thu Dec 18, 2014 11:49 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
Ive used endgrain. It worked just fine.
Jason Moe
LaCrosse WI 54601
PostPosted: Thu Dec 18, 2014 11:50 am
First name: David
Last Name: Falkner
City: Bossier City
State: LA
Zip/Postal Code: 71111
I think a lot of rosettes utilize end grain, especially classical guitars with the repeating patterns of different wood types - ribbons, bands, pyramids, etc.
David
David Falkner - Woodworking YouTube channel and Instagram
Romans 3:23
PostPosted: Thu Dec 18, 2014 2:53 pm
First name: Greg
Last Name: B
City: Los Angeles
Sure, people do it all the time. One thing to keep in mind: it goes way darker than side grain when finished. Just something to be aware of if you're using both. I learned the hard way.
PostPosted: Thu Dec 18, 2014 5:30 pm
First name: Trevor
Last Name: Gore
City: Sydney
All these rosettes are combinations of end and face grain. The middle one is palm.
Here's one in a guitar. It's a FP finish, so the grain just filled in the process.
http://www.goreguitars.com.au
PostPosted: Thu Dec 18, 2014 10:11 pm
Last Name: Beaver
City: Lake Forest
Good looking rosettes Trevor
Joe Beaver
Maker of Sawdust
PostPosted: Fri Dec 19, 2014 2:49 am
I'm planning on using this spaulted birch for a rosette on a future guitar..... It'll warp after cutting but once its stable I'll dimension it and then stabilize it just to make sure it stays flat. I plan on dying this a deep red.
PostPosted: Fri Dec 19, 2014 9:00 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I have had no issues with using end grain in combination with other cuts of wood in my rosettes.
Brian
PostPosted: Sat Dec 20, 2014 2:00 am
Last Name: Curtis
City: Mangrove Mountain
State: N.S.W
Zip/Postal Code: 2250
End grain in Palm is usually how it is used, even seen EGP in antique furniture.
PostPosted: Sat Dec 20, 2014 8:45 pm
I don't think it's a problem either but there is a different point of view on this topic.
I've read a couple of times somewhere over the year in articles discussing just how very clever traditional guitars were designed and built and engineered to both exploit the qualities of wood and avoid the issues with wood that rosettes were also intended to be cross grain braces of sorts, visible cleats if you will in the area weakened by the sound hole.
As such even elaborate rosettes back in the day usually had at least some continuous elements to them spanning the grain in an effort to strengthen that area of the top.
The first time that I read this I thought to myself who knew.... By the second time it reaffirmed my belief that the traditional guitar and it's design are in fact pretty clever considering.
I don't see a problem with end grain but if you want to do a shout-out to tradition perhaps also include some continuous elements to the design.
After looking at the beautiful rosettes posted in this thread they all have continuous elements not to mention there are some pretty cool ones pictured as well!
Users browsing this forum: stumblin, wbergman and 19 guests
